Date/Time: Wed, 25 Nov 2026 07:56:06 +0000
weekly and monthly vwap
View Count: 666
| [2025-09-09 09:12:06] |
| maxm1987 - Posts: 136 |
hi sierra team. I guess it is an easy question but i didnt finde it in the documentation. On a extended trading hours 1-hour chart I want to start a weekly vwap on sunday at market open and a second monthly vwap on the first trading day of the month. I dont know how to do it. I added two vwap stduies and set the input to week /monthy and the period quantity to 1 but im not sure of thats the correct way of doing it or if the vwap includes data from previous weeks/months |
| [2025-09-09 14:34:37] |
| John - SC Support - Posts: 48648 |
From what you describe you have done this correctly. You should see the VWAP reset at the beginning of each week and each month (respectively). You can see where this occurs as the distance of the bands is small when the VWAP resets - it is fairly obvious, as it jumps from wide bands to small. Are you seeing something different that is driving this question? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
