Date/Time: Wed, 25 Nov 2026 07:56:01 +0000
summing up cumulative delta - Bar Delta below bar study
View Count: 1561
[2025-09-09 06:54:55]
User813154 - Posts: 2
I would like to know if there is a way to have the cumulative delta be summed up and show the total number. i use the "Bar Delta below bar" to show the difference between ask and bid volume below each bar. However, i would like the number to show the total number, taking in to account the previous bars number (from start of day).
as an example, in the attached snapshot, i would like the number to show 4 (-2+6) instead of 2. is this possible for me to execute in any way ?
imageScreenshot CDB.jpg / V - Attached On 2025-09-09 06:51:36 UTC - Size: 1.81 KB - 217 views
[2025-09-09 11:15:14]
Tr00pz - Posts: 32
You can use the 'Cumulative Delta Bars - Volume' (or Number Bars Calculated Values with subgraph 10) study along with 'Study Subgraph Above/Below Bar as Text. Set 'Input Study Subgraph' to ID#.SG4. You can set auto-Coloring to 'Based on +/-' to show positive and negative cumulative delta in different colors.
[2025-09-10 06:54:29]
This was what i was looking for. Thank you so much!
