Date/Time: Wed, 25 Nov 2026 07:55:59 +0000
Bar period question
View Count: 439
| [2025-09-08 01:43:43] |
| bskogz12 - Posts: 41 |
Before getting into to0 many details i have a destination chart, lets call it chart 7, and i have two charts 1 and 2 that feed data to chart 7. In chart 7 i limit data, this means that i have less bar periods in chart 7 when using price changes per bar...which is my preferred chart. Can i make custom bar periods that reference the time stamps from chart 7, or is there another way to get chart 1 and 8 to match the time stamps on chart 7. |
| [2025-09-08 04:00:09] |
| Sierra_Chart Engineering - Posts: 25479 |
We do not fully understand this, but you can create custom chart bars: ACSIL Interface - Custom Chart Bars As you construct them you would not be able to reference another chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
