Date/Time: Wed, 25 Nov 2026 07:55:58 +0000
unable to see recent bid/ask volume on DOM
View Count: 581
| [2025-09-05 17:23:07] |
| User449884 - Posts: 238 |
cant seem to be able to add recent bid-ask volume or last size etc on the DOM. ive used it on and off in the pas ton the same DOM but doesnt work now |
| [2025-09-05 18:37:56] |
| John - SC Support - Posts: 48648 |
Refer to the following: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-05 22:33:59] |
all is well, nothing has changed. But those columns when i add them are empty
| [2025-09-08 14:38:00] |
The first thing is ensure that you have the correct columns. If you have the correct columns, then check to see if you have the colors for those numbers set to be the same as the background. Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Recent Bid Volume Other than these, we can not think of a reason for these values to not be displayed. If you continue to have an issue after going through the above, then get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
