Date/Time: Wed, 25 Nov 2026 07:55:45 +0000
Switching to older version
View Count: 1245
[2025-09-05 14:03:12]
User943669 - Posts: 14
Hi Guys,
I am trying to switch to version 2758 but when i do, none of the charts are set up the same. I have tried researching but can not find a solution. Is there a step or process that will make charts from version 2789 look the same on version 2758?
Thank you
[2025-09-05 14:22:52]
In general the charts should not change. There might be differences in the way some studies are calculated and there were changes to the menus that could cause an issue if you go back to a version prior to those changes. We do not recall exactly which release had these menu changes.
What exactly are you seeing that is different in 2758?
Also, we do have to wonder why you would want to go back to a previous version? We work hard to ensure that new versions only improve functionality and that changes that would modify how things work are added as a setting option.
[2025-09-05 15:09:04]
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=126413
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=126414
Here are screenshots of the difference.
I use the older version because I work with KK Kalaway and she wants me to be on same as her (not sure why she uses older versions exactly)
Also when I switch versions, my chartbook goes from 260 KB down to a lesser amount of KB--not sure why or what that means. i then copy over a saved version.
Private File
Private File
[2025-09-05 16:14:28]
You attached the executables in your last post, not the images. Please get us images of what you see between the versions.
