Date/Time: Wed, 25 Nov 2026 07:55:45 +0000
Large Volume Trade Indicator not working
View Count: 628
[2025-09-04 11:48:10]
User305725 - Posts: 1
I have been trying to make use of this indcator but then any time i try to change the max volume for bar SG1 to visible, as soon as i click on apply or ok, it reverts back to ignore. i tried changing teh volume threshold to severeal other different numbers and it is still not working. total trade volume for bar however does not revert back to ignore...
imageScreenshot (1716).png / V - Attached On 2025-09-04 11:42:47 UTC - Size: 198.2 KB - 281 views
[2025-09-04 15:35:33]
Actually, the ability to set the "Total Trade Volume for Bar" to "Visible" and have it stay was a mistake. We have corrected this and it will change in the future so that it is not available.
These items are not meant to be used directly with this study. The issue is that the values are completely different from the pricing data for which the rest of the study is displaying the indicators.
If you want to view the data from these subgraphs, you need to use the "Study Subgraph Reference" or a Spreadsheet Study and then you can have access to the information in those subgraphs.
