Date/Time: Wed, 25 Nov 2026 07:55:59 +0000
The volume is negative- YM
View Count: 449
| [2025-09-04 10:57:58] |
| User716459 - Posts: 204 |
The volume is negative- YM - attachment. Please indicate how to fix it to be positive - GC. Thank you, good day.
Private File |
| [2025-09-04 14:58:34] |
| Sierra_Chart Engineering - Posts: 25479 |
We do not understand this. There is nothing you are showing that shows a negative volume. Provide an image of the chart or Trade DOM, by following these *exact* instructions, and please ensure that the scale for the Volume study in Region 2 is visible: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-04 15:00:41
