Date/Time: Wed, 25 Nov 2026 07:55:48 +0000
RTH TPO chart with full Globex VP
View Count: 513
| [2025-09-04 07:36:27] |
| User707785 - Posts: 10 |
I’d like to display the full Globex Volume Profile using VbP One Period at End of Fixed Time Length (set to 1 week) on a TPO chart. However, I don’t want any overnight TPO profiles to be shown. Would it be possible to add an option like “Exclude Evening Session Profiles Completely”, in addition to the current “Exclude Evening Session Profiles Except For Last Day”? That would be really helpful. Alternatively, is there another method to achieve this? I’ve tried different combinations of Session Times and Sub Periods, but the result is always either: only the RTH VP, or at least one evening session TPO profile at the end (which I don’t want). |
| [2025-09-04 15:13:35] |
| John - SC Support - Posts: 48648 |
You can not get exactly what you are wanting with the current options. The TPO study only has the option for "Exclude Evening Session Profiles Except For Last Day". And the alternative way to solve this is to set the chart to not have an evening session. The only solution is to have 2 charts for this - one with the TPO and one with the Volume by Price - each set as you want. We have noted this as a Feature Request to have an option to not show any evening session profiles even if the evening session is enabled. Note that we can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
