Date/Time: Wed, 25 Nov 2026 16:25:05 +0000
Reverse-button problem
View Count: 702
[2025-09-03 19:29:21]
User135243 - Posts: 337
If I trade 2 contracts I always enter with 2 single contracts (not 2) that I can manage the trades better. From time to time I want to reverse my trade but the system just reverses 1 contract. Not sure where I can find the correct setting to reverse both.
[2025-09-03 19:37:01]
The reversal will be for the quantity you have set for that chart at that time. Since you are entering into a position with a quantity of 1 each time, you must still have the quantity set to 1 when you select the "Reverse" option. If you want a quantity of 2 after the reversal, then you need to set that quantity prior to the reversal.
Refer to the following for ways to change the quantity:
Chart Trading and the Chart DOM: Changing Order Quantity
[2025-09-03 19:49:41]
Ah ok, thanks John, I thought there is a similar setting as I had in the past with the BE-button, there was a setting that I could trail both to BE (and not just 1). No problem, so in this case I've to change the quantity to 2 (I guess twice clicking Reverse will not help). I don't use it very often (because most of the time Reverse is a bad idea :) )
[2025-09-26 17:58:33]
John, once more, would be really nice if you could change this, I trade since 15+ years and know most available trading-platforms, but SC is the only one that doesn't reverse the entire open position hitting the reverse-button. Yes I prefer entering the trades with quantity 1, though I trade 2 or 3 contracts (because the brackets are better to manage).
[2025-09-26 18:12:15]
We have noted this as a Feature Request.
We can not say when we would get to any particular request.
[2025-09-27 10:12:38]
Thanks John, perhaps a similar solution as the BE-button (last or all) would be good.
[2025-09-28 15:07:40]
Sierra_Chart Engineering - Posts: 25481
We will add an option to control the behavior.
[2025-10-14 22:24:34]
The latest release has this option: Global Settings >> Chart Trade Settings >> General >> Position Reverse Method to control the reverse method.
[2025-10-15 08:08:38]
That's great, thank you very much!
