Date/Time: Wed, 25 Nov 2026 07:56:03 +0000
Importing levels to Sierra
View Count: 743
| [2025-09-03 06:29:50] |
| kremat0r - Posts: 52 |
Hello, I need to do one job, I have autoupdating excel file with levels which I want to import to sierra as horizontal lines. I cannot convert this file to .csv because it's updating realtime. I got lost. Can spreadsheet do this? I read manual but cannot get it. I have this file open 24h and now I'm reading levels manually and moving lines manually which takes a lot of effort. Thank you in advance |
| [2025-09-03 15:15:00] |
| John - SC Support - Posts: 48648 |
You would need to create a custom study to do this. Refer to the following: Advanced Custom Study Interface and Language (ACSIL): Introduction https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-03 15:26:08] |
hmm but direct reading of xlsx is not supported in ACSIL
| [2025-09-03 16:12:42] |
ACSIL uses standard C++, so you need to work out how to get the data from Excel in order for it to be used in Sierra Chart.
| [2025-09-03 17:23:26] |
| User719512 - Posts: 548 |
@kremat0r, how is your excel autoupdating? from within excel itself (macros, vb, etc), or some other process?
| [2025-09-04 04:18:40] |
@User719512 There are formulas inside excel, levels are calculated based on data feed and outcome is around 10 levels to plot on chart.
| [2025-09-04 16:29:20] |
I would investigate using OpenXLSX from your Sierra study to read the excel file and keep track of the next time to read from the file based on a hard-coded or input to your study. Since OpenXLSX is as header only solution you can still build with Sierra build systems or using Visual Studio or similar. // pseudocode // init using whatever logic you prefer for study reload // you could also store the last read time in the sc.StorageBlock for better experience if (sc.Index == 0) { persistentLastRead = now() } ... if (persistentLastRead >= now()) { readFromFileAndUpdateLevels(); persistentLastRead.AddSeconds(15); } else { // do nothing; } You get the idea... Happy coding! |
