Date/Time: Wed, 25 Nov 2026 22:50:08 +0000
Automated Trading Limit Order
View Count: 588
| [2025-09-02 14:03:38] |
| Tom_Tom - Posts: 52 |
Hi, is it possible to place a Limit Order at a Moving Avarage. The Limit should change by itself if the Moving Avarage is changing. So the Limit should always follow the Moving Avarage by Itself. THanks for Help Best Regards Thomas |
| [2025-09-02 15:08:07] |
This can certainly be done with a custom study, if that is what you are wanting to do. You just have to continually modify the order as the Moving Average changes. If you are asking if there is a tool for this built into the system, then refer to the information for the "Trade Management by Study" study at the following link: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-05 18:38:44] |
| OctoPi - Posts: 51 |
One of the more basic features of Octopi Trader. Paid SC plugin, free trial for 30 days
