Date/Time: Wed, 25 Nov 2026 07:55:54 +0000
Activate Advance Custom Study button on alert condition
View Count: 555
| [2025-08-29 14:59:09] |
| User615255 - Posts: 1 |
Is there a way to enable a ACS button on a alert condition. for instance bar closes above an MA then it enables button 5.
| [2025-08-29 15:16:05] |
| Sierra_Chart Engineering - Posts: 25479 |
Yes you can do this using an Advanced Custom Study using this function: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: sc.SetCustomStudyControlBarButtonEnable() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
