Date/Time: Wed, 25 Nov 2026 07:55:53 +0000
Modifying Stop In Custom Build Automated Trade Study
View Count: 573
[2025-08-29 12:25:02]
DualADX - Posts: 41
Is it possible with study code, not spreadsheet, to modify a stop in an attached order to move stop from one subgraph to another subgraph based on cross over method? For example, stop is placed on a chosen subgraph study line by design, when price crosses over a subgraph, stop gets moved (modified) to a different subgraph study line. I know there is the Trade Management by Study study, but I want to incorporate this type of stop move into the automation and the Trade Management Study is not in the 8 .cpp files to reference stop modification.
[2025-08-29 20:42:43]
Sierra_Chart Engineering - Posts: 25479
Yes this is possible. You can use the Trade Management by Study as an example:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
The source code of that study is provided. The file is:
AutomatedTradeManagementBySubgraph.cpp
Use this function to modify the order:
Automated Trading From an Advanced Custom Study: sc.ModifyOrder()
Date Time Of Last Edit: 2025-08-29 20:42:49
[2025-08-29 23:24:01]
DualADX - Posts: 41
I cannot find this file in any of the "Studies#" cpp files with a search. AutomatedTradeManagementBySubgraph.cpp
[2025-08-30 02:38:03]
Go to the folder Sierra Chart is installed in and then go to this subfolder: /ACS_Source
In that folder you will see this file:
Date Time Of Last Edit: 2025-08-30 02:38:14
