Date/Time: Thu, 26 Nov 2026 04:33:43 +0000
One click cancel pending orders on order book/DOM
View Count: 752
| [2025-08-28 21:05:23] |
| User528294 - Posts: 10 |
is it possible when you have more than 1 order at one price on the DOM/priceladder, to cancel them all when clicking on 'x' on order notification box. Currently when you click to cancel orders you are met with a menu that has the options to cancel individual orders or an option to cancel all. I would like to remove this, and just have all orders at that price cancelled in one click. I have attached a screen shot. kind regards, |
| [2025-08-28 21:55:47] |
There is not an option to have a single click on the X cancel all orders that are at that price. There is just the option that you already see, which is to click once and then select "Cancel All". Note that what you are seeing is due to having multiple working orders at the same price. If you use the "Scale In" option, then this would make it such that there is a single working order with the total quantity at that price, in which case selecting the X will close out the entire quantity for that order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-07 19:42:19] |
| BTFly - Posts: 20 |
Did you ever figure this out? Have the same question. Thanks
| [2026-04-17 14:34:35] |
| Sierra_Chart Engineering - Posts: 25491 |
We could add an option to cancel all the orders.
| [2026-04-17 16:37:58] |
| BTFly - Posts: 20 |
That would be awesome
| [2026-05-12 23:21:59] |
This new setting will be out in the next release: Chart Trade Settings >> General >> Confirmations >> Cancel All Orders at Same Price Level Without Menu on Cancel Single : Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
