Date/Time: Wed, 25 Nov 2026 07:55:54 +0000
Trade List (Points)
View Count: 728
[2025-08-28 12:22:45]
User688525 - Posts: 403
Hello Sierra Chart,
Is it possible to extract the Profit/Loss in Points or Ticks via ACSIL instead of Currency ($) from the Activity Log? sc.GetTradeListEntry provides TradeProfitLoss.
Thank you
[2025-08-28 13:31:46]
Tony - Posts: 738
This is what I am doing, example of ES Mini, round trip commission is $3.81:
  double CostPointValue = 3.81 / 50;
  s_ACSTrade TradeEntry;
  for (int TradingLogIndex {0}; TradingLogIndex<sc.GetTradeListSize(); TradingLogIndex++) {
    sc.GetTradeListEntry(TradingLogIndex, TradeEntry);
    if (TradeEntry.ExitPrice) {
      double NetClosedPoints {TradeEntry.ExitPrice*TradeEntry.TradeType - TradeEntry.EntryPrice*TradeEntry.TradeType - CostPointValue};
      if (NetClosedPoints > 0) {
        TotalWinPoints += NetClosedPoints;
        TotalWinNumber++;
      if (NetClosedPoints < 0) {
        TotalLossPoints += fabs(NetClosedPoints);
        TotalLossNumber++;
I don't do "scale in, scale out", so my situation is quite simple, and I also ignore the position size
Date Time Of Last Edit: 2025-08-28 13:38:11
[2025-08-28 14:23:04]
Sierra_Chart Engineering - Posts: 25479
We have checked on this, and this function does return the values as currency values:
What you can do is divide these PL values by the sc.CurrencyValuePerTick and then multiply by the sc.TickSize, in order to get Points.
Date Time Of Last Edit: 2025-08-29 15:05:02
[2025-08-29 11:16:27]
Hi Tony,
Thank you for the code. I can use this as a skeleton.
Cheers
[2025-08-29 11:16:45]
Hello Sierra,
Thank you for confirming.
