Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
Chart Header - Standard Text not displaying.
View Count: 483
[2025-08-27 21:42:25]
User327465 - Posts: 23
I have a situation where the chart header text, which is standard text displayed along the top of the chart window, appears above the viewing area. If I maximize the chart, they will come into view, and if I save the chart, they will remain visible when I minimize the window back to its regular size. Why is this happening, and what can I do to remediate this issue? It happens when I share the chart with someone. See attached file.
imageScreenshot 2025-08-27 160307.png / V - Attached On 2025-08-27 21:40:36 UTC - Size: 527.24 KB - 237 views
[2025-08-28 13:51:37]
Sierra_Chart Engineering - Posts: 25479
This is the result of disabling title bars. Enable the title bar:
Chart Menu: Show Title Bar (Chart menu)
[2025-08-28 15:17:29]
I have auto-hide on, but it won't auto-hide the title bar if I show it, so after reading, you say this is a system-level issue. So, there is nothing I can do about it.
[2025-08-28 16:04:46]
Yes, this is a system level issue related to hiding the title bar. There is nothing that can be done about it, apart from not hiding the title bar.
[2025-08-28 16:36:30]
