Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
Broker list
View Count: 638
[2025-08-26 21:57:38]
User625361 - Posts: 8
Hi which broker does sierra support. I have ibkr and amp which one i can use
[2025-08-27 04:03:42]
DFromeaux - Posts: 29
You can use both, but the one that will offer you the best performance is AMP, as they can use TETON directly for order routing.
[2025-08-29 15:55:02]
SC Support - Posts: 2116
We would like to see you with a Broker that supports our CME Teton Order Routing, see the list in #2 here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Teton Order Routing is the highest quality, lowest latency, and lowest cost ($0.00 per contract) option in the entire industry.
