Date/Time: Wed, 25 Nov 2026 16:03:09 +0000
Live data for Python API
View Count: 862
| [2025-08-26 05:26:07] |
| yqz - Posts: 21 |
Hi, I get live data currently through AMP Futures, and am using the service package 11 to get live CME data. However, I would like a Python API where I can connect to and get the data streamed to my laptop and processed in Python. Is this possible? I've search the documentation and it seems like it's not possible, but I wanted to make sure for my situation that it's really the case.
| [2025-08-26 13:34:01] |
You can not get the real-time data. But you can get the data out of Sierra Chart once it has been received in the system. To do this, you would need to create a custom study to do something with the data that you can then pick up using Python. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
