Date/Time: Wed, 25 Nov 2026 16:03:07 +0000
current data on the chart
View Count: 504
| [2025-08-25 17:20:33] |
| User603718 - Posts: 1 |
Hello. Please help me set up the chart to download current data. The CL contract is attached. I've selected automatic rollover in the settings.
Private File |
| [2025-08-25 17:27:38] |
If you do have "Chart >> Chart Settings >> Symbol >> Automatically Rollover Futures Symbol" to "Yes", then the chart should have rolled over to the V contract, as the U contract is no longer being traded. From the CME Group website for the CL product regarding Termination of Trading: Trading terminates 3 business day before the 25th calendar day of the month prior to the contract month. If the 25th calendar day is not a business day, trading terminates 4 business days before the 25th calendar day of the month prior to the contract month.
Therefore, trading terminated for the U (September) contract on August 22, 2025. Check the setting as noted above. If the contract is not rolling over then select "Chart >> Perform Futures Symbol Rollover" to change to the V contract. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
