Date/Time: Wed, 25 Nov 2026 16:03:13 +0000
Horizontal line at the 50 on RSI
View Count: 736
| [2025-08-25 02:54:33] |
| knarf01 - Posts: 49 |
Hello support, I would like to see the 50 line drawn on my RSI but I don’t see an option in the study to enable. At the same time I feel like I’ve had a line at the 50 in the past so maybe I’m using the wrong study or need to enable or disable something to see it. If this does not exist I would like to add it to the requests for future releases hopefully. Thank you! |
| [2025-08-25 12:30:12] |
| Sawtooth - Posts: 4362 |
Add the Line study, and set it to the same Chart Region.
| [2025-08-25 16:20:13] |
The RSI study has inputs for 2 lines that can be displayed. By default, these are set to 70 and 30. If you want just one line, you can set one of the Inputs to 50 and then set the Subgraph for the other line to be "Hidden" or "Ignore" to not display at all. Refer to the following: RSI Sawtooth's suggestion will also work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
