Date/Time: Wed, 25 Nov 2026 16:03:15 +0000
My chart is still showing into another chartbook without actually be in that chartbook
View Count: 549
| [2025-08-23 01:50:44] |
| GravisHTG - Posts: 321 |
I wonder what option I have to remove to do this. Its a chart that I download from a Pay website and this chart always show in other chart and I cant seem to find an option to disable this. I try to talk with the seller , but he too , have no clue Here is the picture of what is happening - And those 3 chart are from the main chartbook and I click on the new chartbook and they are still there ( the 3 charts are a copy of each other ) No matter what Chartbook I open - they still follow. So, does anyone know how exactly I can disable this ? if you need more information - just tell me what you need thanks in advance. Date Time Of Last Edit: 2025-08-23 02:14:33
| [2025-08-23 14:53:38] |
| Sierra_Chart Engineering - Posts: 25481 |
Go to each of those charts and check this Window menu setting for each of them: Window, CB and CW Menus: Window Always Visible (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-23 14:53:43
