Date/Time: Wed, 25 Nov 2026 16:03:13 +0000
add study symbol ES (how to retain the value format)
View Count: 648
| [2025-08-22 15:38:05] |
| User873130 - Posts: 53 |
hi When using add study symbol, example ESU5.CME, the value shows as 640300.00. How do I retain the original value format as 6,403.00? Thanks |
| [2025-08-22 15:38:52] |
Please get us an image of what you are seeing, as this should not be the case, but we want to make sure we fully understand the setup. Follow these instructions to get us the image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-22 21:05:19] |
here it is
| [2025-08-25 19:07:01] |
| Sierra_Chart Engineering - Posts: 25481 |
In this case you need to set the Price Multiplier input with the Add Additional Symbol study to .01: Add Additional Symbol: Price Multipler Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-25 19:07:29
