Date/Time: Wed, 25 Nov 2026 16:03:17 +0000
Use Attached Orders
View Count: 520
| [2025-08-22 13:09:14] |
| MajuroCapital - Posts: 6 |
Hello, So, I'm using attached orders. For example, for a 10-lot position with target 1: 10 ticks, stop 1: 20 ticks, quantity: 5, and target 2: 20 ticks, stop 2: 20 ticks, quantity: 5. When I select the move to breakeven for stop: Step 1, Type OCO group Triggered and Triggered OCO group: 1. When my target 1 is hit, it brings stop 2 of my target 2 back to breakeven. How can I make it bring stop 2 back not to breakeven but +1 or +2 ticks from breakeven? Because when I want to change the BE level offset, I can only select 6 or 9. Thank you in advance for your feedback. Sincerely. |
| [2025-08-22 13:20:58] |
| Sierra_Chart Engineering - Posts: 25481 |
This does not make sense. This is just simply a field, where you can enter any number positive or negative as a number of ticks: Because when I want to change the BE level offset, I can only select 6 or 9. Refer to: Attached Orders: Move to Breakeven for Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
