Date/Time: Wed, 25 Nov 2026 16:03:03 +0000
Getting the Required Margin for Symbol
View Count: 585
| [2025-08-21 20:09:44] |
| Marek F - Posts: 254 |
Is it possible to get the Required Margin (Exchange Margin and Account Margin) for symbol via ACSIL? Thank you |
| [2025-08-22 19:40:01] |
| Sierra_Chart Engineering - Posts: 25481 |
No, this is not supported. We will have to see about adding a function for this. But it is not straightforward to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
