Date/Time: Wed, 25 Nov 2026 16:03:19 +0000
Enable Trade Activity Log
View Count: 629
| [2025-08-21 17:05:40] |
| Cileron - Posts: 52 |
Every time I want to export my trade activity I have to manually click edit tab and uncheck Disable Trade Activity Log. How can I make it to where is remained unchecked so when I can go to export that would be one less step i have to do to pull my trades The message I see when opening Trade Activity Log is: " Disabled (Uncheck 'Edit>>Disabled Trade Activity Log' |
| [2025-08-21 18:08:43] |
So you are stating that the option for "Edit >> Disable Trade Activity Log" is enabled every time you open your Trade Activity Log? Even if you did not have that option enabled when you last closed the Trade Activity Log? This should not be occurring. It should keep the state of that selection whenever you close the window and open it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-21 18:15:44] |
Yes I have to manually uncheck disabled trade activity every time even if i unchecked it last time. i want it to automatically enable trade activity log . so i can see my trade without having to do anything extra
| [2025-08-22 19:39:24] |
| Sierra_Chart Engineering - Posts: 25481 |
You need to disable risk manager mode: Trade Account and Risk Management: Setting Sierra Chart to Risk Manager Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
