Date/Time: Wed, 25 Nov 2026 16:03:01 +0000
How do I hide my account number from the trade activity log?
View Count: 1040
| [2025-08-21 15:03:07] |
| xORDERBOOKx - Posts: 191 |
I'm trying to show my executions to someone and it would be convenient to screenshot the window without having to edit it with MS paint to blur out my account number. I'm talking specifically about the "Trades" tab in the Activity Log, where the "Symbol" column will show both the symbol and the account number. I can manually drag the column to cover this, but it would be easier to have a feature disable it, which is also beneficial if I want to File->Save Log As and not have to worry about personal data showing up in the export. Thank you. |
| [2025-08-21 15:45:42] |
There is no option to not display the account on the "Trades" tab. That is there to differentiate the trades for different accounts. We have set this as a "Feature Request", although we can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-21 16:33:11] |
Understood. Thank you.
