Date/Time: Wed, 25 Nov 2026 16:03:05 +0000
Volume at price threshold alert V2
View Count: 824
[2025-08-21 14:58:04]
User837393 - Posts: 161
I have a question on the ln:6 entery of the study and the numerous SG parameters (SG1 to SG47) in subgraph study.
Are the subgraph study SG parameters (width for say) linked with the ln:6 ? What I mean is let say I choose a 10% on ln:6 and I set a increasing width of the Draw style selected from SG1 to SG46, will the Draw style will increase to the selected width every thime the threashold is increased by 10%.
Is this correct ?
[2025-08-21 15:42:56]
There is no link between the "Percentage Threshold" and the size of the markers from the study. The size of the markers is constant and set by the Width setting for the subgraphs.
[2025-08-21 16:16:49]
Thank you for the quick answer. Then let say SG1 marker is set at width 8 and SG2 marker at width 10.
What will make SG2 marker to print vs the SG1 marker?
[2025-08-21 17:59:56]
Each subgraph represents the n'th instance of the threshold being met within a bar. So the first price that is found that meets or exceeds the threshold will be marked with SG1, the second price point that meets or exceeds the threshold will use SG2 and so on.
[2025-08-21 19:00:50]
So if I want to have the size of the marker varying based on volume at a given price, what would be the study to use then ?
[2025-08-21 19:17:57]
The "Large Volume Trade Indicator" can do this, but it gives slightly different information, as it is the total volume traded above the threshold. Refer to the following:
