Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
OCO Stop Breakeven Step Not Working while App is Closed
View Count: 565
| [2025-08-21 07:35:46] |
| User325260 - Posts: 5 |
Hi, Will breakeven steps on OCO stops work while Sierra Chart is closed. I am trying to apply move to breakeven steps to stops on a OCO while Sierra Chart is closed. I thought updated my orders to be server side but I doesn't like the stop moves while the sierra chart is closed. Thanks |
| [2025-08-22 22:56:31] |
| Sierra_Chart Engineering - Posts: 25481 |
No this functionality will not work when Sierra Chart is not running. Refer to: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-25 05:14:19] |
Got it. Thank you clarifying.
