Date/Time: Wed, 25 Nov 2026 16:03:01 +0000
How to know SCT_ORDERTYPE_LIMIT_CHASE; is actually chasing?
View Count: 536
| [2025-08-20 00:39:55] |
| User944318 - Posts: 65 |
I am backtesting an acsil study where my entry has an attached child target which is set to chase. When I backtest this study, it doesn't appear to chase. How can I fix this?
| [2025-08-20 13:55:51] |
Which back testing option are you using?
| [2025-08-20 15:24:15] |
Replay back test
| [2025-08-20 18:50:06] |
Check the "Trade >> Trade Orders Window" and make sure the order type is correct: Trading Information Windows: Trade Orders Window What did you set the Maximum Chase amount to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-20 20:07:07] |
The order type is correct. How do I set the maximum chase amount?
| [2025-08-20 20:43:10] |
Refer to the following: Basic Trading and the Trade Window: Set >> Maximum Chase for Chase Limit Orders For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
