Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
Housekeeping issue for chart calc tool config
View Count: 424
[2025-08-19 15:08:50]
User98657 - Posts: 420
I just noticed that the Chart Calc Tool Configuration Horizontal Text alignment appears to be reversed.
Mine is set to "Left", with the Text Vertical Alignment set to "Above", and Draw Text At End set to "Yes".
With this configuration, the text is drawn to the right, not the left.
Once you know, it's not a big deal. Just wasn't sure if anyone had called it out previously. I probably wouldn't want it to change now because I'd have to go back and change my configurations, so this is NOT a complaint.
[2025-08-19 17:14:45]
It is not something we would change, as you state, it would require everyone to change their configurations and the way they already think about this.
The reason it is this way is due to how Microsoft references where the text is located within the box that is defined for the text.
