Date/Time: Wed, 25 Nov 2026 16:03:19 +0000
multiple TP values
View Count: 531
[2025-08-19 07:21:41]
User936721 - Posts: 32
Hello
I am not sure if you can help me?
I am placing a single market or limit order, with 2 lots = TP for first is say 10T and TP for 2nd TP say 30T. The SL is say 20T away with a BE move when TP 1 is hit
All of above works well
What I'm trying to do / work out, is IF I place a scale in limit or stop order (ie between entry and TP1, or between entry and SL), and it executes, I want the quantities of the initial orders to BOTH increase from 1 to 2. Ie TP1 was 1L now 2L and same with TP2 - but what I am seeing is that TP1 remains at 1L and TP2 becomes 3L
I'm sure this is a simple order management function, but I can't find the correct setting to use.
Any help is appreciated
Thank you
[2025-08-19 16:23:33]
Refer to the following:
Global Trade Settings Windows: Scale In (Global Settings >> General Trade Settings >> Scale In/Out)
[2025-08-19 20:50:26]
Thank you SC John. Very fast and effective response
