Date/Time: Wed, 25 Nov 2026 16:03:18 +0000
Relative Volume Standard Deviation
View Count: 591
| [2025-08-18 03:44:06] |
| blt - Posts: 231 |
To: SC Team Would it be too much of work to add in "Subgraphs" option to change default color (RED) for bars Vol under SD "Freedom of Movement" would be another indicator where that option would be welcomed (also RED by default) Thank you very much Leonardo |
| [2025-08-18 21:32:00] |
In this case, it is something very simple to make those subgraphs have the secondary color showing so you can change it. As such, we have taken care of this and the change will be in the next Pre-Release (version 2784). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-18 21:55:50] |
| blt - Posts: 231 |
... John-SC Support and all others SC Wizards What you doing guys is bloody OUT OF THIS WORLD !!! Massive Pure Perfection Thank you Thank you Thank you Also Please deduct from my acct. $50.00 as a minuscule sign of appreciation for your amazing work attitude and professionalism I authorized that in full |
| [2025-08-19 15:51:06] |
Thank you for the offer of payment, but it is not necessary, and not something we would take. These changes were very straightforward, and we do not understand why it was not setup this way from when those studies were added. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
