Date/Time: Wed, 25 Nov 2026 16:03:20 +0000
Issue with DOM graph display
View Count: 605
[2025-08-15 15:04:05]
casssim - Posts: 2
I have an issue with volume number display in DOM Graph.
The problem is when there are higher values on a given price level - numbers are overlapping (especially 3 digits numbers) and we can't see it properly.
Please have a look at the attached printscreen.
I tried to solve it with different setting in Chart -> Market Depth Window but it didn't help at all.. I also tried to change global settings with ChatGPT support but it didn't help.
Can you advise which settings needs to be modified to solve it? For me it doesn't matter how it can be solved - I mean these numbers can be displayed on the left of the bar or column might be bigger or numbers are smaller etc.
Regards,
Date Time Of Last Edit: 2025-08-15 15:04:51
imageDOMGraph.JPG / V - Attached On 2025-08-15 15:04:02 UTC - Size: 57.69 KB - 311 views
[2025-08-15 16:09:49]
Sierra_Chart Engineering - Posts: 25481
Refer to:
Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM
[2025-08-17 23:40:05]
casssim - Posts: 2
Thank you for your response but I didn't find a solution under the link you provided. I'm talking here not about customization but about an issue with number display using default settings when I enabled DOM graph after your application installation.
I tried to solve it by customization changes from the link you provided but it didn't help.. For me it looks like an application error, nothing has impact on these numbers/column display.. Numbers are overalpping, colum is still the same, font doesn't change at all whatever I do.. If according to you it's a matter of some settings then please advise which settings exactly need to be changed here to solve this.
Regards
[2025-08-17 23:50:51]
What did you set this to: Chart >> Chart Settings >> Market Depth >> Market Depth Combine Increment in Ticks:
Here again is the documentation:
Date Time Of Last Edit: 2025-08-17 23:51:32
