Date/Time: Wed, 25 Nov 2026 16:03:17 +0000
Cant see footprints data
View Count: 567
| [2025-08-15 09:40:01] |
| User981251 - Posts: 1 |
Hi, I am using Denali with CME bundle but I dont see any footprints data on my charts, how I fix this? The attached photo is NQ, but ES is the same. Even when I create a new chartbook, and apply the Number Bars, it shows my a blank chart. Date Time Of Last Edit: 2025-08-15 09:46:34
| [2025-08-18 18:04:13] |
We see that you are currently evaluating package 12, so you should be fine now. If you are still having an issue, then please let us know what exactly is occurring. Note that the evaluation is only for 30 days, so after September 14, 2025, the evaluation will be over and you will not be able to use the Numbers Bars study, as you are currently on the "Integrated Standard" package. Therefore, you will need to change to one of the "Advanced" packages at that time to continue to use the Numbers Bars study. Follow these instructions to change your package: Sierra Chart Purchase and License Information: Changing Package For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
