Date/Time: Wed, 25 Nov 2026 16:03:21 +0000
Studies Large Trade Text, Large Trade Graphic
View Count: 885
| [2025-08-14 19:23:05] |
| preetbanwait - Posts: 21 |
Hello Sierra Chart Support, I am trying to locate and apply the same studies shown in the attached screenshots — specifically the Large Trade Text and Large Trade Graphic studies. However, I am unable to find these studies in my Sierra Chart. Additionally, when I use the Large Trade Volume Trade Studies > Draw Volume Text option and set it to Transparent, the numbers still display with a dark solid background (First heatmap image). In the second heatmap image (created by someone else), the numbers are displayed without any solid background, exactly how I would like them to appear. It appears that they had these Large Trade Text, Large Trade Graphic studies applied, but I am unable to replicate this setup or find these exact study names in available list. Could you please let me know: How I can locate or enable these studies in Sierra Chart? How to make the text display fully transparent (no background) like in the second image? Thank you for your help. Best regards, Preet |
Attachment Deleted. |
| [2025-08-14 19:23:43] |
Please check this another Heatmap2 attachment.
| [2025-08-15 15:55:45] |
| Sierra_Chart Engineering - Posts: 25481 |
Here is the documentation for the Large Volume Trade Indicator: Large Volume Trade Indicator Set the Marker Style to None: Large Volume Trade Indicator: Inputs This is right: Draw Volume Text option and set it to Transparent, The only other study that matches somewhat with the names you are giving is this one: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-15 15:56:15
| [2025-08-15 16:24:04] |
Thanks for the feedback, I am aware of that - if you look Heatmap 2 image there are circles showing with the text in between transparent style. I figured other person is using the custom study to achieve that UI. I am not sure if I can do that with available studies on Sierra chart. If that's something can be achieved in future with Large trade Volume Indicator study with keeping the circles and show text in between with transparent style. The purpose for this to achieve the results same as Bookmap in Sierra Chart Heatmap. Let me know if there is something I am missing out. Thanks Preet |
| [2025-08-18 20:34:09] |
In the "Large Volume Trade Indicator" set the following: - Marker Style: Circle - Draw Volume Text: Transparent For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
