Date/Time: Wed, 25 Nov 2026 16:03:10 +0000
AMP/teton: TradingDOM 6EU/M6EU bid order not getting through
View Count: 493
| [2025-08-14 15:08:54] |
| User353585 - Posts: 69 |
hi, I'm unable to enter limit bid for trading symbol M6EU while using 6EU as charting symbol of tradingDOM following is the message from TAL: ActivityType DateTime TransDateTime Symbol OrderActionSource InternalOrderID ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity TradeAccount OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID HighDuringPosition LowDuringPosition Note AccountBalance ExchangeOrderID ClientOrderID TimeInForce Username IsAutomated Orders 2025-08-14 11:03:05.892584 2025-08-14 11:03:05.892577 M6EU25_FUT_CME 6EU25_FUT_CME/M6EU25_FUT_CME[M] #3 | Trade DOM/User order entry | Last: 1.16815 | AOE=false | AOU=false 743 Limit 1 Buy 11662.0000 Order Sent 208556 Open 0.00 Day N Orders 2025-08-14 11:03:06.076361 2025-08-14 11:03:06.076355 M6EU25_FUT_CME Teton CME Routing (New). Info: Order from DTC client #44387. Sierra Chart. 127.0.0.1 743 5973400 Limit 1 Buy 11662.0000 Pending Open 208556 Open 0.00 743.13148 Day N Orders 2025-08-14 11:03:06.076395 2025-08-14 11:03:06.076394 M6EU25_FUT_CME Teton CME Routing (Order reject). Info: CME (Rejected). Text: Order price is outside bands 'Bid of 11662.00 violates High Band 1.1742 using Delta .00, C.Last equals 1.1682'. SecurityID=42078222. Operator=208556 743 5973400 Limit 1 Buy 11662.0000 Error 208556 Open 0.00 8820971450360 743.13148 Day N limit ask (sell) orders work okay. just limit bid (buy) orders are not going through. please let me know what to do, thank you. Date Time Of Last Edit: 2025-08-14 15:32:15
| [2025-08-14 15:11:57] |
| Sierra_Chart Engineering - Posts: 25481 |
For the proper settings for this configuration, refer to: Sierra Chart Teton Futures Order Routing: Using Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-14 15:16:38] |
I think it's different kind of problem. I applied the setting and it still don't work. could you review?
| [2025-08-14 15:21:31] |
The problem is what the documentation explains and the correct settings to use are all there. If you do not want to apply the documentation, then at this point use a separate chart for each symbol. Do not use the Trade and Current Quote Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-14 15:22:22
| [2025-08-14 15:46:34] |
okay, I thought it was feed problem since it worked in trading evaluator server. Now I solved the problem, thank you
