Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
Currency and Ticks at Order Lines in more Instances
View Count: 454
[2025-08-14 13:10:55]
Tom_Tom - Posts: 52
i have opend more instances.
So if i send a order in Chart Trading from the main Instance, i see always the currency and ticks on order lines in the main instance, but in the other instances same symbol i dont see this information.
If i send my order from a other instance, i can see it in this instance and in the main instance. But not in other instances.
Thanks for Help
Best regards
Thomas
[2025-08-14 13:33:10]
Sierra_Chart Engineering - Posts: 25481
We are not exactly sure what you are referring to, but all of the capabilities and functionality, regarding an order, are only fully available, in the instance the order was entered from.
[2025-08-14 13:49:38]
Tom_Tom - Posts: 52
Hi thanks for Answer.
Yes i think so.
But if i send my order from the main instance. i cant see the currency and tick information on the orderline in the higher instance.
if i send the order from the higher instance i see it in this instance, and in the main instance.
So main instance i can see it always. But other instances i can only see it if i sent it from this instance.
[2025-08-14 13:50:56]
We do not know exactly what you are referring to:
However, whatever you are seeing, must be just how it is. This we are certain of.
Date Time Of Last Edit: 2025-08-14 13:51:03
[2025-08-14 13:51:57]
Tom_Tom - Posts: 52
ah ok only full available in the instace the order was enterd. maybe this is the problem
[2025-08-14 14:26:17]
Tom_Tom - Posts: 52
hi i have made a picture of my problem
imageUnbenannt.png / V - Attached On 2025-08-14 14:25:07 UTC - Size: 94.76 KB - 179 views
[2025-08-14 14:56:08]
We cannot help with this. The screenshot is illegible.
