Date/Time: Wed, 25 Nov 2026 16:03:12 +0000
Open Order within SC - Unable to close
View Count: 543
[2025-08-14 12:32:55]
SierraMatthew - Posts: 36
I had an open order yesterday that got closed while Sierra Chart was not active and it did not recognize the trade closure and showed I still have an open position. I made a manual trade log entry to close it and it did connect the dots on the chart, it was unsuccessful in showing the open position. I flattened the position which then lead to a short position with my broker so that doesn't seem to work either.
Without clearing the trade log, how can I force Sierra Chart to recognize the trade that was closed yesterday?
Thank you so much.
[2025-08-14 12:37:15]
Sierra_Chart Engineering - Posts: 25481
Are the position quantities shown, if any, in Trade >> Trade Positions Window incorrect?
[2025-08-14 13:01:14]
In the trade positions window it is still showing QTY 1. I apologize I should have been more clear. When I attempted to flatten the position within Sierra Chart I did so in the Trade Positions window.
[2025-08-14 13:02:35]
I have also deleted and re-downloaded all chart data, refreshed trade data, switched the trade data and translated the symbols to their services with no effect.
[2025-08-14 13:31:04]
If you see an incorrect position in Trade Positions Window when you are using Teton order routing then contact your broker and have your broker, insert a manual fill to offset that:
Trade Account and Risk Management: Add Manual/Correcting Order Fill
Date Time Of Last Edit: 2025-08-14 13:31:20
[2025-08-14 13:35:27]
The fill was done outside of Sierra chart. I do not have an open position with the broker.
[2025-08-14 13:51:05]
Edit: Thank you that resolved it. Have a great day.
Date Time Of Last Edit: 2025-08-19 17:05:02
