Date/Time: Wed, 25 Nov 2026 07:55:49 +0000
[Programming Help] - scid files
View Count: 850
| [2025-08-14 12:00:14] |
| GARYtheG - Posts: 37 |
Hello Sierra Team, whats the time logic sierra uses in the scid files? the numbers look quite huge |
| [2025-08-14 13:45:21] |
| Sierra_Chart Engineering - Posts: 25479 |
Refer to: Intraday Data File Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-05 12:32:14] |
is there a way to understand the logic of the raw data thats coming from the memory and not the scid file? i have very different numbers in between those 2 raw datapoints
| [2025-09-05 14:04:44] |
| John - SC Support - Posts: 48648 |
The data starts in the file, then is loaded and turned into the bars that make up the chart. The actual individual trades that make up the bars that are stored in the .scid file are not kept in memory. Although that should not make any difference. What exactly do you mean by "I have very different numbers in between those 2 raw datapoints"? We need more information on what you are viewing, how you are viewing it, and what you are comparing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-05 18:58:11] |
i was pulling data from the memory with a bridge! to implement them in some calculations running outside of sierra! and i was looking at raw data from the scid file! and there were different raw time datapoints! But as I understand the scid file updates already quite fast? I might just take the data fromt he scid file and erase the bridge completely! how long does the data processing from the denali datafeed take to be seen in the scid file?
| [2025-09-05 19:07:30] |
Intraday File Flush Time in Milliseconds (0=default) i could lower that setting to get the data faster from the buffer into the scid file?
| [2025-09-06 15:19:44] |
Yes this is true.
| [2025-09-13 12:17:15] |
is there any difference in the scid files from the stocks condolidated tape and the scid files from the denali data feed like nq? i try to extract data from the stock files but always get a as the latest data, data from March 2024! tick storage is set to 1
