Date/Time: Wed, 25 Nov 2026 16:15:01 +0000
Auto enable order allocation
View Count: 555
| [2025-08-12 14:03:53] |
| Cileron - Posts: 52 |
How do I Auto enable order allocation to multiple accounts without having to manually go in a make sure its turned on every time i load Sierra. As of right now I have to turn it on everyday even though I had it on the previous day
| [2025-08-12 14:26:32] |
| Sierra_Chart Engineering - Posts: 25481 |
Refer to: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) Make sure that option is set to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
