Date/Time: Wed, 25 Nov 2026 16:03:10 +0000
DOM chartbook width changed
View Count: 587
[2025-08-12 03:15:33]
DoubleM - Posts: 9
How do you change the width of VBP study on on DOM as a chart. The numbers are cut off and I can't find where to change the width so the VBP study is visible. Can you direct me to where to adjust I couldn't find it after searching for some time.
Thank you
Date Time Of Last Edit: 2025-08-12 17:30:37
Private File
Private File
[2025-08-12 04:15:24]
Sierra_Chart Engineering - Posts: 25481
This is hard for us to understand what the cause is unless we actually have that particular chart.
Our recommendation is just to put the Volume by Price study on a standard chart with bars not on a Trading DOM.
Date Time Of Last Edit: 2025-08-12 04:16:08
[2025-08-12 13:51:59]
We were thinking about this some more, check this Input on the Volume by Price study, on the Trading DOM:
Volume By Price Study: Always Display Last Profile Within View
It needs to be set to Yes.
Our suggestion to use a standard chart is to help to troubleshoot this easier and to understand what the issue is and so there are less potential issues, since the price bars can be seen.
Date Time Of Last Edit: 2025-08-12 13:52:50
[2025-08-12 14:37:57]
DoubleM - Posts: 9
The VBP study is specifically set for the DOM so it can reasonably expected to work on the DOM chart. As you can see on the left hand side of the picture with the max bar width percentage set at 100% the bars surpass the edge of the chart and no amount of adjustments with the cursor makes the chart wider than the bars. Has my program been hacked by nefarious actors, is it SC team has not been able to update those chart studies or is there a way to increase the DOM width to fully show this study.
[2025-08-12 18:48:07]
DoubleM - Posts: 9
By the to not be a complete ass. SC is an awesome platform and wickedly stable.
[2025-08-13 19:51:52]
We really have to get that particular Trade DOM chart to look at it. Attach it by following these instructions:
