Date/Time: Wed, 25 Nov 2026 16:14:55 +0000
[Programming Help] - Account Management.
View Count: 467
[2025-08-11 18:20:29]
jgc1123 - Posts: 4
Recently I had to add the Denali Exchange ($39.00 per month) to my DOMs to clear an error message and receive real tiime data. Prior to that issue, I was using the Service package 10 ($36.00 per month). Do I still need the Service Package in conjunction with Denali or does Denali provide what I need to trade from the CME and COMEX markets?
[2025-08-11 19:13:24]
Sierra_Chart Engineering - Posts: 25481
You need both the Service Package, and the exchange fee.
[2025-08-11 19:25:21]
jgc1123 - Posts: 4
Got it, thank you. Also, If I change brokers in order to use the Teton Service, Do I need anything different or updated from Sierra or does th ebroker do it all?
[2025-08-11 21:56:09]
The broker takes care of everything. Although you do need to set Sierra Chart to use Teton order routing. Instructions are here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Date Time Of Last Edit: 2025-08-12 02:51:25
