Date/Time: Wed, 25 Nov 2026 16:15:00 +0000
corrupted stock chartbook
View Count: 537
[2025-08-11 15:12:51]
User993113 - Posts: 83
Since this morning, I have been experiencing a serious issue with corrupted stocks chartbook. This problem occurs on both SC instances I have saved on my PC. The problem seems to be limited only to the chartbook containing the stocks; the other chartbooks related to futures (which, moreover, also contain identical studies) appear to be working normally.
Here’s what happens: after saving and closing the platform correctly, when I reopen my stock chartbook, the Alert Manager window appears, reporting — for some studies on certain tickers (specifically the up/down volume divergence I set through an Alert Condition) — a formula error that, in reality, does not exist, because before closing the platform everything was working normally.
After that, when I open the chart, the following occurs:
1) A large part of the charts within the saved chartbook are missing.
2) Instead of the ones I saved, other charts (other Tickers) appear.
3) All charts are renamed with a different name from the one I set (for example, the chart named “NVDA” becomes “NVDA (CBV-D)”).
4) The studies I had set are gone, except for the divergence-related ones, and another study that I did not insert appears.
5) The price is no longer displayed: the price scale on the right is empty, and the text “nan” appears at the top. If I try to adjust the scale, nothing happens; if I reset the scale, only whole numbers appear, and no candlesticks are displayed.
as I no longer know what to do.
I would like to avoid having to go through the trouble of rebuilding my entire chartbook from scratch.
Thanks in advance
[2025-08-12 03:52:16]
Sierra_Chart Engineering - Posts: 25481
Usually an issue like this would be relating to running out of Windows operating system resources. How many charts are within the Chartbook?
Check the Window >> Message Log for errors when opening the Chartbook.
Check this Menu setting, in relation to the charts that should not be appearing:
Window, CB and CW Menus: Window Always Visible (Window)
To resolve this,:
Set this to None:
Chart Settings: Continuous Contract (Chart >> Chart Settings >> Symbol >> Symbol menu)
For the scale issue, refer to:
Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales.
There are backup Chartbooks available:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
Date Time Of Last Edit: 2025-08-12 03:53:04
[2025-08-12 09:14:12]
The settings were already correct as per your instructions, and I had already tried using “reset scale” without any results.
I had also forgotten to mention that all the timeframes had been converted to 1 millisecond (!)
The good news is that I didn’t know about the backup folder, and that actually worked.
I was able to recover the chartbook, open it without any errors, and save it under a different name.
So everything is resolved, with the recovery of the backup chartbook.
Thank you
[2025-08-12 13:59:26]
Okay this is good. It does sound as though there was some type of corruption which would be very rare.
Date Time Of Last Edit: 2025-08-12 13:59:32
