Date/Time: Wed, 25 Nov 2026 16:14:55 +0000
Data not updating
View Count: 554
[2025-08-11 14:34:12]
User582666 - Posts: 13
I have paid everything regarding access to F.US.EPU25 but the symbol is stuck at the same value.
If I switch to "SC Data - All services" it works and it updates, but if I remain on CQG, it's stuck at the same value and not updating.
Why is this happening? What do I need to change?
Thank you.
[2025-08-11 14:51:59]
Sierra_Chart Engineering - Posts: 25481
To solve this, activate the particular CME exchange that you need, here:
Date Time Of Last Edit: 2025-08-11 14:52:09
[2025-08-11 14:59:19]
I have bought Denali. Maybe there is a contract that I have not signed or something. I've been using Sierra since October last year and this is the first time I get this.
[2025-08-11 20:24:56]
We see you are using CQG. It has long been required, that the Denali Exchange Data Feed needs to be used with CQG:
CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges
There was a period of time recently, where this technically had not been implemented but it has always been the policy.
Also you are running an old version of Sierra Chart and it is a strongly recommended to update. Instructions:
Date Time Of Last Edit: 2025-08-11 21:37:15
[2025-08-12 02:43:59]
[✔]- Your Service Package supports activating exchanges with the Denali Data Feed.
[✔] The Denali Data Feed is active.
[✔] CME / CBOT / NYMEX / COMEX Exchange Agreements
I have Denali bought and active.
Everything worked fine until 1st of August.
Did something change from 1st until yesterday?
Thanks.
imageScreenshot 2025-08-12 at 05.37.29.png / V - Attached On 2025-08-12 02:40:28 UTC - Size: 29.17 KB - 259 views
[2025-08-12 03:10:25]
You still have not activated the exchange that you need. This is done here:
[2025-08-12 09:59:36]
My Denali expired on July, 31st. I bought it again. Works now. Ticket can be closed.
Thanks.
