Date/Time: Wed, 25 Nov 2026 16:15:02 +0000
Crude Oil Trading
View Count: 499
| [2025-08-10 19:38:46] |
| User904434 - Posts: 76 |
I can not connect platform with WTI Crude Oil. Can you check pls ?
| [2025-08-11 08:51:17] |
I have CQG data feed and under Sierra Denali data feed it should work or I miss some settings ?
| [2025-08-11 13:43:44] |
| Sierra_Chart Engineering - Posts: 25481 |
You need to activate the NYMEX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
