Date/Time: Wed, 25 Nov 2026 16:15:04 +0000
installer
View Count: 473
| [2025-08-10 15:46:18] |
| Dennis B. - Posts: 303 |
Running 2764, no problems. Tried to install newest version and all I get is a installer icon on my taskbar. Nothing happens, just sits there ??
| [2025-08-11 19:10:52] |
| Sierra_Chart Engineering - Posts: 25481 |
Right-click on the installer icon and close it. Try again after that.: Software Download: Fast Update If you still have problems use the zip installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-11 19:11:22
| [2025-08-11 19:22:04] |
I can't find software download fast update, where is it ?
| [2025-08-11 21:40:37] |
Just did it the old way and it updated fine ? weird...
