Date/Time: Wed, 25 Nov 2026 16:15:05 +0000
Problems TimeZone and Day start on chart....
View Count: 499
[2025-08-09 20:46:09]
MTScalper - Posts: 35
I’m experiencing an issue where, even though I have set the New York session times from 18:00:00 to 17:59:59, the chart still always starts the trading day at 00:00:00. It seems to ignore the custom session settings.
This behavior is causing problems with some indicators I’m developing — for example, my projected daily percentage calculation lines are supposed to start at 18:00 (New York session open), but instead they are starting at midnight.
Could you please advise what might be causing this?
Thanks for any reply
[2025-08-09 22:27:05]
I solved it in ACSIL by using the session start and end times for the period lookback and for the start of the day.
