Date/Time: Wed, 25 Nov 2026 16:14:54 +0000
Activate Alert Sound on Erase Lines Tab
View Count: 487
[2025-08-08 11:49:09]
User757746 - Posts: 20
Erase Lines Tab previously made alert sound upon pressing "yes" now it is silent. Need direction to reinstall alert sound.
[2025-08-08 14:39:38]
We do not know what you are referring to in terms of the "Erase Lines Tab".
[2025-08-08 17:00:06]
On the Control Bar the Button Labeled Erase Non Text Drawings (Erase\Lines); previously when I used the Button to delete "all non-text drawings" there would be an Alert Sound upon choosing "yes." The Alert Sound is no longer working and I do not know where to find the place to re-activate it. In the "helps" area there are directions for deleting sounds, but I have not found where to enable. Please advise. Thanks.
[2025-08-08 18:57:44]
We do not recall the "Erase All Non-Text Drawings" having a sound associated with it. And there is definitely not a way to associate a sound with a specific Control Bar button.
We will check with Engineering to see if the "Erase All Non-Text Drawings" had a sound associated with it at some point.
[2025-08-08 23:51:59]
Sierra_Chart Engineering - Posts: 25481
This was never the case. We cannot think of a reason why there would ever have been the triggering of an alert when deleting a Chart Drawing.
[2025-08-09 12:02:29]
OK, all I know is that upon clicking the "yes" dialogue box a sound (call it a beep) and the non-text drawings would erase.
[2025-08-09 13:51:47]
We do not know why that was the case. It could not have been Sierra Chart generating the sound.
