Date/Time: Wed, 25 Nov 2026 16:15:05 +0000
Shapes above/below bars partially overlap with bars - Horizontal offset for shapes?
View Count: 434
[2025-08-07 20:56:54]
speculator069 - Posts: 2
I have a problem with a study that places markers (square / triangles) above and below bars.
The problem is that the shapes are overlapping with the bars.
Is there a way to offset the shapes to the upside and downside?
On the screenshot you can see that the triangles and squares are hiding parts of the bars.
https://www.sierrachart.com/image.php?Image=1754600159128.png
[2025-08-07 21:13:08]
Whether you can offset them depends on how you are getting those items displayed in the first place.
If you are using a Sierra Chart study, then let us know which one.
If you are using a custom study, then you need to change the value of the subgraph where those items are being displayed and calculate an offset to place them where you want them.
[2025-08-08 17:58:36]
Yes it's a custom study.
I will try to offset them in the code
