Date/Time: Wed, 25 Nov 2026 16:15:04 +0000
How to split Stop orders with quantity>1
View Count: 500
| [2025-08-07 12:30:22] |
| User512353 - Posts: 198 |
Suppose a simple Trade Window setup with - Main: Market order, quantity 1 - Targets: Stop: Stop, quantity 1 When in the Main tab I now select a different Order Quantity Button than 1 and I submit the order, the attached Stop order will have the same, higher quantity. What I want to have is Stop orders that I can move individually, independently. E.g. I submit a market order of 3, and then have 3 separate stop orders that I can move around individually. Is there any way to achieve this with some settings? I know that I could create separate configuration profiles for each quantity, each with the required number of Stop orders. But this is not a good solution for me, because I have many stored configurations and the selection process takes too long, So, I would rather just click an Order Quantity Button. Date Time Of Last Edit: 2025-08-07 13:45:11
| [2025-08-07 14:31:43] |
No there is no other solution other than using Trade Window Configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Also you can add control bar buttons and Keyboard Shortcuts to access those: Control Bar: Control Bar Trade Window Configuration Buttons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
